BissHub service is online
BissHub is the biss key pool of hellobox. If you have a biss key that autobiss does not support, you can submit the key to BissHub, and then your hellobox can open the program corresponding to the key.
Service URL : https://www.freedvb.com/bisshub
				[email protected]
Re: BissHub service is online
Apa maksud nya.?
				creaturebaba
Didn't work for Idman on hellobox v5 hd
				drtamersh
Great idea.. Still not tested yet , but for hellbox smart2 , how it will detect that new bisskey was added from other device??hellobox wrote: ↑Fri Apr 16, 2021 8:58 amBissHub is the biss key pool of hellobox. If you have a biss key that autobiss does not support, you can submit the key to BissHub, and then your hellobox can open the program corresponding to the key.
When the device cannot open a program, the device will report to the server, and the server will calculate the correct key or search the correct key in the pool. There are tens of millions of candidate keys in the pool.drtamersh wrote: ↑Sat Apr 17, 2021 5:32 amGreat idea.. Still not tested yet , but for hellbox smart2 , how it will detect that new bisskey was added from other device??hellobox wrote: ↑Fri Apr 16, 2021 8:58 amBissHub is the biss key pool of hellobox. If you have a biss key that autobiss does not support, you can submit the key to BissHub, and then your hellobox can open the program corresponding to the key.
				drtamersh
Tried with many biss encrypted feed channels
But nit working at all
				drtamersh
i try it with different feeds but not working
				drtamersh
ok once i will get a feed iwill upload here
