Crypt8 online calculation test run
NETMEDIA
Re: Crypt8 online calculation test run
Post by NETMEDIA » Sun Feb 03, 2019 8:17 am
Today I tried to get a CW from Crypt 8. I entered the crypt to the online site however even after 20 minutes still the message computing please wait. I could only find in my V1 tables not V2.
Asiasat5 100.5e
3925 v 7200 ID: ABL SLINGERS V CSL KNIGHTS
Search Crypt8 in TS Start
TS file: C:\Users\POTUS\Desktop\100.5E_3926.322_V_7200_(2019-02-03 16.06.53)_dump.ts
Using PID: 4110
Using file limit: 4096 MByte
File length: 470 MByte
UsingFileLen: 493118360 bytes
Reading file ...
Searching ...
Using payload size: 184
PID:100Eh B8h-Crypt8: C1 C8 4E C6 99 6F DC E1 [E] Count:35814
Time for searching Crypt8 = 1 sec.
Search CW Start
RBT file: F:\Biss V1 file\B8hx00h\B8hx00h_table1\CSA_B8hx00h_10000h.rbt
Calc all 10000h end values for this crypt ... (using file cache)
Search end values in RBT ...
Searching CW in RBT ...
Found 135758 possible chains (harddisk only search time = 66 sec.)
Analysing chains ... (will be 10 times slower if an other thread is keeping the GPU busy)
found CW: 20 19 FE 37 ED 03 02 F2
Search CW done (70 sec.)
If evolution works, why so many idiots?
Post by hellobox » Sun Feb 03, 2019 3:26 pm
Asiasat5 100.5e
Using PID: 4110
Reading file ...
Searching ...
Search CW Start
Because the server handling the RBT V1 table is down. The server has now been restored.
Post by hellobox » Sun Feb 03, 2019 3:29 pm
NETMEDIA wrote:
Sun Feb 03, 2019 8:06 am
Sun Feb 03, 2019 7:11 am
NETMEDIA wrote:
Sat Feb 02, 2019 6:46 am
I noticed for today that for the A League from Asiasat5 100.5e 3945 v 7120 that until I posted the crypt so the CW could be found the Hellobox would not update until the CW was found.
So the Hellobox does depend on whether or not for new CW that someone has posted the crypt to the online system.
Once the CW was found the channel would open on the V5 Plus.
I have done this a few times now and found the Crypt and CW on my own system and had my channels open but the V5 Plus did not open until I posted the crypt and the system found the CW. Interesting.
Hellobox also crawls Crypt8, but due to the size limit of the set-top box memory, it can't cache too much data, so some Crypt8 that can be successfully crawled on the PC can't be crawled on the STB.
Hope to solve your doubts.
Thanks for your explanation. I always delete old CW from the stb so I don't keep a lot of data in the stb.
Also when the stb does get the CW when I look at the CW in the stb it never matches what I get from the crypt8.
Any reason for this?
The CW stored in the STB has been encrypted.
satelitindonesia
Post by satelitindonesia » Mon Feb 04, 2019 11:43 am
there is a page for watching cw that has been calculated?
Receiver Satelit Indonesia :K0S , K2 , K3, K5S
tarcito
Post by tarcito » Mon Feb 04, 2019 2:21 pm
I couldn't find this c8 with online tool
PID: 65h B8h-Crypt8:7D 1B 35 4A F3 76 81 46 [E] Count:3272
100.5e 4247v7200
NETMEDIA
Post by NETMEDIA » Tue Feb 05, 2019 3:21 am
100.5e 4247 v 7200
No such frequency possible on AS5
NETMEDIA
Post by NETMEDIA » Fri Feb 08, 2019 9:45 am
I am not sure why you do this as some members would like to use box to get CW and post CW in forums or FB groups.
For me not an issue but some others I know like to help post CW and I do not see why you would encrypt the CW.
tarcito
Post by tarcito » Fri Feb 08, 2019 3:06 pm
I couldn't find the c8 on the site.
75W
3870 H 5000
PID:048Dh B8h-Crypt8: FB 9C AD 44 B8 03 88 D4
Post by hellobox » Sat Feb 09, 2019 2:47 am
Why do you need a CW list?
Post by hellobox » Sat Feb 09, 2019 3:16 am
Autobiss was first implemented on STB by freedvb two years ago. The original design prevents CW from being stolen by other set-top box manufacturers by encrypting CW.
