edzus1 wrote: βThu Jul 02, 2020 5:06 pm
Hey.
Thank you for adding a full 7 day EPG.
But there are bugs in the firmware:
1 When you enter standby mode, Hellobox 8 NEW freezes and in order to exit out of freezes Hellobox 8 NEW,  reboot is required (power off)
2. If want to record the program from the EPG using the green button, TIMer setting. Noticed 2 errors:
2.1 the setting of the engine location is lost. USALS -> Set location
2.2 there are 21 timers with the choice OFF or ONCE
when checking the list of timers there are no 21 timers. (this problem is mentioned here
http://www.freedvb.com/viewtopic.php?f=25&t=18836  there is the screen itself 21 timers
I tested several firmware:
Hellobox8_20190725
Hellobox8_20191031
Hellobox8_20200410
Hellobox8_20200522
  The result is 21 timers everywhere, but there are no 21 timers in the timer list )
Due to 1 error when switching to standby mode, the new firmware 20200630 cannot be used.
Correct these errors so that you can update Hellobox 8 NEW.
P.S.
I had to go back to the created backup that I created before checking firmware 20200630
