Hellobox 8 firmware release 20210521A
Re: Hellobox 8 firmware release 20210521A
with later versions you have the problem of false standby and the useless consumption of current, with H8 old version I don't have it.
The version I use is the: 2020 12 07 all subsequent ones do not bring any advantage for me, moreover I have H8 old version and I don't know if these new firmware have also been tested on this one.
Hellobox 8 flaws we have reported have never been fixed to date.
regards
I do not switch to the October firmware 202001027A due to the fact that the processor remains under full load when the timers are programmed (I need the timer as an alarm clock )Cluster.One wrote: ↑Sun May 23, 2021 4:08 pm
regards
My tests http://www.freedvb.com/viewtopic.php?f= ... 128#p30564 are shown in detail on GIF - pictures, like my Hellobox 8 NEW starting with firmware 202001027A, already when switching to standby mode, the processor remains under full load at ~ 0.5W when, with the correct program code Hellobox 8 NEW should switch to real standby mode with consumption from processor in ~ 0.02W Correctly standby mode works in versions including up to 20200904 firmware.
Since DVBplayer has opened the satellite settings state, hellobox8 has not been disconnected, so you think it's a crash.
In fact, you just need to disconnect DVBplay and Hellobox8.
Technical
I do not understand How to do it. The DVB player was disconnected. Even after restarting Hellobox 8, he is still there.
kriku1972
Auto biss and power vu keys are not autorolling in many tp in Intelsat 17 and Intelsat 20 still even after this firmware update. Please fix this problem.
Isabel2020
erhan75
156e d3 not working, why isn't this fixed?
Powervu is auto-rolling on Intelsat20 Cband...BBC ,SKY,CNN.. working well, as well as CNBC with the right key/softcam.
REM; Sony package not fixed yet.
kriku1972
