Have notice it too when you do blind scan it run faster and as my brother said you won't capture all of the TP San help fix the issue in your next firmware.
Hellobox 8 firmware release 20210209A
Arbourboateng
Re: Hellobox 8 firmware release 20210209A
formula
My device died after the update, what should I do? The red bulb only works?
sathex
don't worry...My device died after the update, what should I do? The red bulb only works?
just use loader with any official firmware
no need dump
just choose a good platform
i think is
SYMPHONY UPG DDR2
like i said here :
http://freedvb.com/viewtopic.php?f=28&p=32001#p32001
enjoy
formula
thank you, but it's not work with me, error msg:sathex wrote: ↑Wed Apr 14, 2021 2:04 amdon't worry...My device died after the update, what should I do? The red bulb only works?
no need dump
i think is
SYMPHONY UPG DDR2
like i said here :
enjoy
sync error.
i am used usb ttl ft232bl!
sathex
something wrong with the connection !thank you, but it's not work with me, error msg:
sync error.
Top
here a 2nd solution
http://freedvb.com/viewtopic.php?f=25&t=21242
Technical
Dvbplayer in hellobox 8 freeze (crash software). After connecting dvbplayer in hellobox 8 the box crashes after opening the satellite settings. After restarting, the box remains freeze there. Correct this problem.
