Biss Koqit Decoding
Torrita
Biss Koqit Decoding
Post by Torrita » Sat Dec 07, 2019 5:49 pm
Hello from Italy
I have a problem with a Koquit like this: the BISS channel is automatically decoded, in 4: 2: 2 I only hear the audio, but the code that shows me is not the right one. I can't use it to put it on my DVBDREAM.
Does anyone know this problem?
Re: Biss Koqit Decoding
Post by fenddick » Tue Dec 10, 2019 3:18 am
Hello from Italy
The code is encrypted
temp10
Post by temp10 » Tue Dec 10, 2019 4:15 pm
Hellobox or KOQIT are based on DVBfinder, these devices don't say their users real BISS keys. but you should use PVR function. When decrypted 4:2:2 channel is recorded on usb stick, it can be watched on VLC played .
If you see DVBfinder page while you are recording 4:2:2 channel, it is a problem. It's solution is you can change another fta channel's TP with the TP which you want to record. But you should take care that 2 channels must have same SPID. SPID is 4th number on screen. It can't be changed manually. If you want to learn real BISS, you can buy SKYSAT V20mini.
Pionex2020
Post by Pionex2020 » Fri Dec 13, 2019 9:24 pm
Is the Koqit box supported here?
