Hellobox 8 firmware release 20200707
Post by fenddick » Wed Jul 08, 2020 8:50 am
  • Youtube update.
  • After the version is upgraded, the following will be saved(Fav group name,wifi password).
  • The timing function in the EPG menu will be fixed.
  • Fixed Standby crash and Time accuracy.
  • Add the function of inputting the wrong password 10 minutes after 5 times.
Hellobox8_20200707.rar
(4.29 MiB) Downloaded 1336 times
Re: Hellobox 8 firmware release 20200707
Post by Yawwilson » Wed Jul 08, 2020 9:58 am
We do very much appreciate your hard work... thanks
tonsat
Post by tonsat » Wed Jul 08, 2020 10:25 am
Thank you very much
Post by Cluster.One » Wed Jul 08, 2020 1:03 pm
Thank you so much!
Myworld
Post by Myworld » Wed Jul 08, 2020 3:39 pm
We appreciate your hard work helping us...thank you
scollrocker
Post by scollrocker » Thu Jul 09, 2020 6:16 am
thanks
IceT
Post by IceT » Thu Jul 09, 2020 11:19 am
Thank you vert much.
The box here in Italy has LCN iussue
The numbers assigned of the DTT channels are not the same of the normal italian's LCN. Some channels has another number that the usuals numbers. Could you fix this iussue?
Post by fenddick » Fri Jul 10, 2020 1:37 am
We‘ll check it.
floating
Post by floating » Sat Jul 11, 2020 10:45 am
what is ther password to open and use youporn?
Post by edzus1 » Sat Jul 11, 2020 11:54 am
Is it difficult to read the forum? Read the first page of the forum in the Hellobox 8 section to the end to get a response.
http://www.freedvb.com/viewtopic.php?f=25&t=18119
