Hellobox 8 firmware release 202001027A
Re: Hellobox 8 firmware release 202001027A
Post by Cluster.One » Thu Nov 05, 2020 11:57 pm
edzus1 wrote:
Thu Nov 05, 2020 10:57 pm
You checked with firmware 20200904 (released at the beginning of September, he clock in standby mode is in a hurry for a dayby 16 minutes and the standby mode is normal (the load on the processor is minimal).
But with the firmware 202001027A released on October 27, things are different - the transition to standby mode, the processor remains under full load (the controlled signal does not fall on the standby mode electronic key (1MQ2 according to the scheme)); therefore, the processor does not go into standby mode and remains under full load and the voltage at the output of the LNB is also constantly applied (the heads on the satellite antenna remain energized in standby mode, which in standby mode should not be) But the clock with this full processor load in standby mode runs exactly a minute per minute.
No, I checked with firmware 20201027 Hellobox 8 old version.
After one minute that Hellobox 8 is in standby mode the meter oscillates between 0.000 and 0.020mA
Tomorrow I will measure with a tester and I will also check if in standby mode the LNB voltage is present or not, but if the meter I used today is not wrong it shouldn't be there.
in standby mode clock continues go faster!
Post by edzus1 » Fri Nov 06, 2020 2:52 am
I have Hellobox 8 NEW version.
Fredy
Post by Fredy » Fri Nov 06, 2020 2:07 pm
Una pregunta me hellobox 8 no me deja actualizar x usb me sale no soportado alguien me puede inforamar x que???
Fredy
Post by Fredy » Fri Nov 06, 2020 2:25 pm
Una pregunta x que mi hellobox 8 no me deja actualizar x usb me sale no soportado alguien que me pueda ayudar??
Post by Cluster.One » Fri Nov 06, 2020 5:02 pm
Why is USB not supported? Use a completely empty USB pen drive of a few gigabytes formatted fat32.
¿Por qué no se admite USB? Utilice un pendrive USB completamente vacío de unos pocos gigabytes con formato fat32
Post by Cluster.One » Fri Nov 06, 2020 5:53 pm
I made new measurements and confirm what was written previously.
Time displayed in standby is not accurate minutes run faster...
Hellobox 8 old version Firmware 20201027
Post by edzus1 » Sat Nov 07, 2020 9:42 am
It turns out that the October 20201027 firmware works correctly on Hellobox 8 OLD version, but the firmware does not work correctly on Hellobox 8 NEW version.
P.S.
It turns out the new firmware 20201027 - the firmware was tested only on Hellobox 8 OLD version, and with Hellobox 8 NEW the firmware version 20201027 was not tested.
Both versions of Hellobox 8 have the same design, but the filling (electronic circuit is different)
Post by Cluster.One » Sat Nov 07, 2020 10:10 am
I don't know exactly how things are, If is true that the old Hellobox 8 and the new one have different hardware, is it possible that the engineers test the firmware only on the old one??? :shock:
If it's true it's not possible to act like this!!!
Either you abandon the old Hellobox8 but it's not right :evil: or you make two different firmware, one for the old version and one for the new.
P.S.
Post by edzus1 » Sat Nov 07, 2020 11:23 am
P.S.
The filling is different (electronic circuit). At first glance, the location of the components (parts) is visually similar, but those who disassemble in the diagrams will find that these 2 boards with different diagrams
Post by Cluster.One » Sat Nov 07, 2020 12:07 pm
Thanks for sharing this useful information, it is clearly visible that hardware is different.
It is the first time I see inside new version of Hellobox 8.
