My comment was also clear. The pics in first post show V5 plus. I don't need to know if the software is V5 or V5 plus. It must be clearly stated when posting. I joined group. Only found HB_V5Plus_SRG NETWORK and auto_burn.fac. You should learn the process to install auto burn. Why take time and effort to created a software only to change date & version???
Waiting New firmware v5 plus 2020
Re: New firmware v5 plus 2020/03/06
SAM I 10'- Dreambox DM800HDse-Hellobox-GTMedia
Well, the auto_burn.fac for V5PLUS is also 4mb.... have installed it and it's okay the only drawback for now is only my 3g modem works..my WiFi adapter is not working...I believe the programmer forgot to install the WiFi adapter drivers...
Rem: there are two auto_burn.fac(s) one for V5HD and other for V5PLUS
This software (auto_burn.fac) was programmed with South East Asia in mind..so if you live outside that region you have to delete all channels (only) in factory reset.. but if you do absolute factory reset (ie,all), then you will have to figure out where to change the language back to English.
which could give some of us some headache!
Well, now, to the Hello box engineers, I do humbly suggest that in releasing a new software, they should incorporate all that is in this auto_burn.fac (software)..
Link pls
Now that people is using the auto_burn.fac resulting on wifi connection problems, it is necesary to released an official new update as soon as posible fixing the problem and adding features as new V5HD released: Update Youtube & Support for new 3G Dongle(D-Link)
After above auto burn flash my box is not startup , nothing display shows in box it's not power up
Re: Waiting New firmware v5 plus 2020
Plz give me v5plus new softwer link ..thanks
