Ac3 lockup
				Pionex2020
Ac3 lockup
I am having a problem with my Hellobox V5 Plus such that it is locking up on some of the tv channels with ac3 audio, the only way to regain control of the receiver is to remove the satellite cable and power off and on again. If I change the audio for the channel causing the lockup I would get video but no audio on that channel and the receiver will work normally. Would you be able to assist me with correcting this issue? also the audio on this receiver is half the volume level of that on all my other video sources.
				Pionex2020
Re: Ac3 lockup
1 week, 48 views and no replies. Does that mean this issue cannot be fixed?
Re: Ac3 lockup
Is the channel encrypted?Pionex2020 wrote: ↑Sun Mar 24, 2019 7:21 pm1 week, 48 views and no replies. Does that mean this issue cannot be fixed?
				Pionex2020
Re: Ac3 lockup
Thanks for the reply.
It locks up on both encrypted and free to air channels.
Galaxy 15 @ 133W
tp 3790H: Sr 11936
tp 3808H: Sr 16303
The receiver locks up on those channels with ac3 audio.
Galaxy 15 @ 133W
tp 3790H: Sr 11936
tp 3808H: Sr 16303
- DVBFinder
Re: Ac3 lockup
Dear,
please check if you are using the latest firmware for V5 plus, as I remembered the old version would has this kind of problem.
if you have already upgraded to the latest version, and the audio problme is still existed, please record a stream file from this TP and send to us for debugging. thanks!
Please follow our Facebook Pages:
DVBFinder
DVBPlayer
Hellobox Electronics
						DVBFinder
DVBPlayer
				Pionex2020
Re: Ac3 lockup
I have the 20190311A firmware on the receiver.
				Pionex2020
Re: Ac3 lockup
Thanks for the reply.DVBFinder wrote: ↑Sun Mar 31, 2019 4:04 amDear,
Here are links to recorded streams.
Code: Select all
https://drive.google.com/file/d/1JAvDfbPzi4kO9pb4gVR-RMkCSNMIpBWi/view?usp=sharingCode: Select all
https://drive.google.com/file/d/1jJFII8rYEFhCGW7j30MF1-IX-_mMwlUZ/view?usp=sharingCode: Select all
https://drive.google.com/file/d/1QQzyLx8UIj3fYaS-vXJHNGQpmHG0nTLF/view?usp=sharing-
				Pionex2020
Re: Ac3 lockup
Are there any updates to solving this issue?
				Pionex2020
