TP Satelit Problem
Sundriver
TP Satelit Problem
Post by Sundriver » Fri Mar 22, 2019 8:48 am
Hello
i have a new Hellobox V5 Plus. We are in Europe and i need the Astra Satelite 19,2E
In the Hellobox are 3TP saved but Astra hast 107 TP.
How can i install the 107 TP?
Regards
BABRA LUNGU
Re: TP Satelit Problem
Post by BABRA LUNGU » Fri Mar 22, 2019 12:02 pm
use this link www.flysat.com
Sundriver
Post by Sundriver » Fri Mar 22, 2019 4:37 pm
I tfind it not good that something is not pre-installed
Sundriver
Post by Sundriver » Fri Mar 22, 2019 4:46 pm
The box is new, made a update and now BESTTV is an Error 404 nothing happens any more
Post by fenddick » Mon Mar 25, 2019 2:20 am
Hello
Regards
Is there any other box can search 107tp available?
if not,may be your antenna is not aligned with the satellite.
if right,may be you should set the correct LNB freq .
Post by gxu » Mon Mar 25, 2019 1:42 pm
no need to preload, use blind scan,everything comes
