Multi streaming
tariq
Multi streaming
Post by tariq » Fri Dec 06, 2019 3:36 pm
can i watch multiple chanels simaltanously on multiple mobiles?
avruk71
Re: Multi streaming
Post by avruk71 » Sat Dec 07, 2019 8:44 pm
No
stevechretien111
Re: Multi streaming
Post by stevechretien111 » Sat Dec 21, 2019 1:17 am
Hi,
I'd like to know if there is a way to stream 1 channel to multiple devices at the same time?
1 hellobox smart s2, 1 channel, multiple device at the same time.
If not, can it be implemented in a next firmware update?
I have 3 lnb so 3 different channels to cast so maybe buying 2 other smart s2 to complete my setup.
Dont want to pay for an expensive sat<IP server.
avruk71
Re: Multi streaming
Post by avruk71 » Sun Dec 22, 2019 2:29 pm
use tvheadend 1 ch to multi devices, or VLC player
stevechretien111
Re: Multi streaming
Post by stevechretien111 » Sun Dec 29, 2019 5:23 pm
OK, thank you.
I will test it, but it could ne great since rtsp is often use to stream to multiple devices.
I noticed that un dvbplayer there's a place to entre command, what kind of command are supported? None to change the rtsp server parameters!?
stevechretien111
Re: Multi streaming
Post by stevechretien111 » Sun Dec 29, 2019 5:29 pm
Well there was a place, can't find it anymore.
Probably removed.
