Remove other languages from the stream ?
Quicksilver
Post by Quicksilver » Wed Sep 04, 2019 10:15 pm
Da some way to iptv m3u playlist turn off other languages? Because I am trying to create a playlist that would work via SMART IPTV, but if I play a stream that contains multiple languages in it, it just won't run and I still see the buffer ... thanks for the advice
avruk71
Re: Remove other languages from the stream ?
Post by avruk71 » Thu Sep 12, 2019 9:48 am
what program are you using? and which smart TV?
Quicksilver
Post by Quicksilver » Fri Sep 13, 2019 8:16 pm
SMART IPTV
https://siptv.app
If they use a basic player on a TV where there is one language so it plays, but if I play something that has multiple languages ​​so the tv will not drop and it writes me buffering ... the solution is to play TV via VLC external player, but worked through the basic.Autor application does not respond to email.
avruk71
Post by avruk71 » Sun Sep 15, 2019 4:54 pm
for LG u have usefull
EPGcode,Channel Name,http://channel.stream.address,en
en - Your audio stream
for LG with NetCast
http://siptv.eu/howto/playlist.html
and audio stream code ONLY LG
http://www.loc.gov/standards/iso639-2/php/code_list.php
If U have LG with WebOS , audio select red button on RC.
Quicksilver
Post by Quicksilver » Sun Sep 15, 2019 5:59 pm
I use to play android BOX XIAOMI MI BOX 3, which can handle all video formats. I even tried a test playlist and everything worked, but here's just a problem, but just as I mention in the multi stream: _- (I come from the error is on the application itself and the author how to respond to emails. Thanks for the effort.
