How can i add one tp only?
Diyaa
Post by Diyaa » Fri May 03, 2019 10:33 am
Hi i need to add one tp to sat . Can i add one by one?
iggy57
Re: How can i add one tp only?
Post by iggy57 » Fri May 03, 2019 1:48 pm
Open DVBplayer
Top right select settings its the Gear wheel
Select Installation
Select Satellite that you want to add tp to by pressing and holding that selected sat
A pop up will come up select TP and then tap The green plus button top right corner there you will be able to add the TP you are wanting to add.
Tap the green Check mark when done
Hope that helps
Diyaa
Post by Diyaa » Fri May 03, 2019 5:41 pm
thank you :D
