keys Patch Menu
Re: keys Patch Menu
Working on PowerVU packed on 4.8 E
AU keys woking ? .
AU keys woking ? .
Re: keys Patch Menu
Very good. Congratulations on the new firmware. I was able to configure and import a softcam file. Powervu channels opening without problems After I imported the SoftCam file. Excellently. Smart S2 is undoubtedly an innovative and excellent appliance of this type, no other equal to compete.
- DVBFinder
Re: keys Patch Menu
- wx_20190213144758.png (19.54 KiB) Viewed 10602 times
Please follow our Facebook Pages:
DVBFinder
DVBPlayer
Hellobox Electronics
DVBFinder
DVBPlayer
- Joey
Re: keys Patch Menu
This version not support account import,you can config them by DVBPlayer Server menu.Next version will be OK.aab44 wrote: ↑Wed Feb 13, 2019 8:57 amI removed .txt (I use .txt to upload to forum)
I tried with .key and .cfg files , but still import = 0
Format file picture attached.
Please check screen record video:
http://www.mediafire.com/file/mxmflqqia ... y.mp4/file
Re: keys Patch Menu
Please show some details about Biss/PowerVu format of softcamfenddick wrote: ↑Thu Jan 31, 2019 2:39 amThis BOX supports two ways to import key:Jussiedb wrote: ↑Wed Jan 30, 2019 10:29 pmIn the new firmware was added the option of loading a softcam keys file for Keys Powervu and Biss in the DVB Player menu. This is probably via the USB connection. Unfortunately, using that special USB / P2 cable with a connected pen drive, the system does not recognize the connected drive, nor does it make it possible to select the drive with the softcam file even though a USB flash drive is connected to the device.
1. If you have a USB connection, you can insert the USB automatic import (file name is softcam. key).
2. Put the softcam. key file into the mobile phone and remember the path,open app and enter the Device menu,select the key file under the path just now, and click Update to import.
biss/powervu 在softcam中怎么写?请详细一些。
Re: keys Patch Menu
#BISS KEYSs2tv wrote: ↑Sun Feb 24, 2019 4:55 pmPlease show some details about Biss/PowerVu format of softcamfenddick wrote: ↑Thu Jan 31, 2019 2:39 amThis BOX supports two ways to import key:Jussiedb wrote: ↑Wed Jan 30, 2019 10:29 pmIn the new firmware was added the option of loading a softcam keys file for Keys Powervu and Biss in the DVB Player menu. This is probably via the USB connection. Unfortunately, using that special USB / P2 cable with a connected pen drive, the system does not recognize the connected drive, nor does it make it possible to select the drive with the softcam file even though a USB flash drive is connected to the device.
B 4150:30000:H 1234567812345678
F 000100FF 00 1234567812345678 ;0001:SID;00FF:VideoPID(Forbidden 1FFF/0000)
#POWERVU KEYS
P 605c02 00 1234567812345678
P 605c02 01 1234567812345678
#IRDETO KEYS
I 0604 02 DFDD0C4B92B4ABD26514B9AF9F0C79C4
#VIACCESS KEYS
V 030B00 0D 1BCA9E886D4EBD52DA1610613C4805C1
Re: keys Patch Menu
Thanks but i have some questions,please help me explain.fenddick wrote: ↑Mon Feb 25, 2019 9:29 am#BISS KEYSs2tv wrote: ↑Sun Feb 24, 2019 4:55 pmPlease show some details about Biss/PowerVu format of softcamfenddick wrote: ↑Thu Jan 31, 2019 2:39 am
#POWERVU KEYS
#IRDETO KEYS
#VIACCESS KEYS
#BISS KEYS
Question 1:
Are SID and VideoPID Hexadecimal ?
Question 2:
Do i need to write two lines like below?
Or do i only need to write 1 line like below?
#POWERVU KEYS
Question :
What is “605c02 ” ? video pid ? or what ?
#IRDETO KEYS
Question :
What is “ I 0604 and 02” ? video pid ? or what ?
#VIACCESS KEYS
Question :
What is “ I 030B00 and 0D” ? video pid ? or what ?
Re: keys Patch Menu
1.yess2tv wrote: ↑Tue Feb 26, 2019 2:10 amThanks but i have some questions,please help me explain.fenddick wrote: ↑Mon Feb 25, 2019 9:29 am#BISS KEYS
#POWERVU KEYS
#IRDETO KEYS
#VIACCESS KEYS
#BISS KEYS
Question 1:
Question 2:
#POWERVU KEYS
Question 3:
#IRDETO KEYS
Question 4:
#VIACCESS KEYS
Question 5:
2.no
3.provider id
4.provider id & key index
5.provider id & key index
Re: keys Patch Menu
Thanksfenddick wrote: ↑Tue Feb 26, 2019 6:42 am1.yess2tv wrote: ↑Tue Feb 26, 2019 2:10 amThanks but i have some questions,please help me explain.fenddick wrote: ↑Mon Feb 25, 2019 9:29 am
#BISS KEYS
#POWERVU KEYS
#IRDETO KEYS
#VIACCESS KEYS
#BISS KEYS
Question 1:
Question 2:
#POWERVU KEYS
Question 3:
#IRDETO KEYS
Question 4:
#VIACCESS KEYS
Question 5:
2.no
3.provider id
Question 2:
F 000100FF 00 1234567812345678 is one line ok ?
Question 3:
#POWERVU KEYS
What is provider id ? how can i get it ?
Re: keys Patch Menu
Please i need your urgent help on smart S2 patch file for biss, please help me create a file and add this tp
11555H29999
Idman
1001102110017081
CBC
1313133913131339 please use it and leave it here in this group don't broadcast on facebook
11555H29999
Idman
1001102110017081
CBC
