Hellobox 8 firmware release 20190725
[email protected]
Re: Hellobox 8 firmware release 20190725
hello,
I downloaded the latest version 20190725.
After upgrading via USB, Favorite channels disappeared.
l rolled back to older dump they reappeared.
is there a way to upgrade firmware via USB and maintain favorite channels?
please help
please help
luixmax
Hello everyone, AC3 + is not compatible which makes it useless for T2, a big mistake. Another bug that still inherits from hhellobox V5, when you change the audio track you lose the sound, you have to change the channel up or down to recover the sound. Very disappointed, I hope that the compatibility with AC3 + is solved or in a short time this box will be useless. Greetings.
Next Version will fix this bug(audio track no sound).luixmax wrote: ↑Tue Aug 06, 2019 7:41 amHello everyone, AC3 + is not compatible which makes it useless for T2, a big mistake. Another bug that still inherits from hhellobox V5, when you change the audio track you lose the sound, you have to change the channel up or down to recover the sound. Very disappointed, I hope that the compatibility with AC3 + is solved or in a short time this box will be useless. Greetings.
AC3+ not support
luixmax
hello, the wifi signal when it has been connected for a while stops working despite the fact that in the menu it indicates that it is connected, by Lan cable there are no problems.
paisoekhant
T2 channel is not ok.
maicol72
Please check 4:2:2 scrambled feed (biss). The video stream on DVBPlayer or vlc stop immediately.
With 422 free feed it's all ok
pinolo
magicman
is it possible to add EMM's to this receiver?
Sanjayadarmadasa
66e intelsat 17 and 68e intelsat 20 Sony network and discovery net work not working
Auto biss key not working
