EPG
Quicksilver
EPG
Could you please add the option when choosing a television also see what where they give? I know there is an EPG in the settings, but when switching up and down I don't see what else it is. Just the station name. Still have another problem with the existing EPG where the application can not hooks and commas so in the words are nonsense could it fix? Thanks for your time and great box.
Re: EPG
EPG is obtained from satellite streamsQuicksilver wrote: ↑Sun Aug 25, 2019 4:30 pmCould you please add the option when choosing a television also see what where they give? I know there is an EPG in the settings, but when switching up and down I don't see what else it is. Just the station name. Still have another problem with the existing EPG where the application can not hooks and commas so in the words are nonsense could it fix? Thanks for your time and great box.
Quicksilver
Re: EPG
But the application of DVBPLAYER to primo EPG does not show. When selecting a program, it pisa maximally the station name. Even when I switch the television there I see signal strength, quality and station name. Could you also add information about the program, what they give and what will follow? Dale Epg what there is not recognize our diakrytiku ňščřžáýéí. Thanks for repairing and possibly adding info epg.
Re: EPG
we will have a discussion.Quicksilver wrote: ↑Wed Aug 28, 2019 3:35 pmBut the application of DVBPLAYER to primo EPG does not show. When selecting a program, it pisa maximally the station name. Even when I switch the television there I see signal strength, quality and station name. Could you also add information about the program, what they give and what will follow? Dale Epg what there is not recognize our diakrytiku ňščřžáýéí. Thanks for repairing and possibly adding info epg.
Quicksilver
Re: EPG
Thank you very much for the great support from your side about resolving EPG display. Would it be in the plan to add epg what they give and also follows in the place where the names of television? And then what do I run the program to and down where the signal strength, quality, the name of the station, if there was even what they give? Thanks for the solution and also a great box under the TV
