103 west 3820 needs emm key to make the keys roll.
they roll often.
does anyone have emm key and does anyone know how to enter into v5 plus
How to enter emm key
Will123
Re: How to enter emm key
You enter the EMM keys in the same manner as you would the ECM keys.
1. Open your menu and select Expansion
2. Select Key Edit
3. Select Power VU
4. Select Add (green button)
once you've entered the screen you must first delete the entry already there and then simply add the correct information.
5. Exit and save
I've found it easier if I'm adding or editing several keys to do it on my computer. To do this first dump your keys onto a USB flash drive. Then put the flash drive in your computer and open with Notepad. Add and/or edit the information then save it back to your flash drive. Insert that back into your receiver and import back into your Expansion.
Check your PM for the EMM key.
2. Select Key Edit
3. Select Power VU
5. Exit and save
7 1/2 ' mesh dish, Titanium C1 PLL Titanium ASC1 Dish Positioner Freesat V 8 Super Hellobox V5 Plus
leehrat
thanks for the info. will give it a try and see if they roll from now on.
leehrat
ecm keys work fine but the emm keys entered do not roll the keys. guess we need a new bin file for list.
Pionex2020
