hellobox8
- gxu
Re: hellobox8
It's not easy for common user to input emm key, because the chipset has some limitations that is too professional to explain. But if you have some emm keys, you can send to us and we can add them by network to the box.
Re: hellobox8
Is it possible to import keys into Hellibox8? .....if yes,then softcam keys contain emm keys ...or
- machteck
Re: hellobox8
Sometimes, you don't see the keys but it wofks..which implies the keys are stored hidden otherwise you can use a softcam editor (eg quickedit for Android) to edit the keys.. removing unwanted keys before importing
- machteck
Re: hellobox8
Thes are keys i have acquired from different sites and members that i stored and edited with notepad and then loaded on the usb drive when i have to do a complete factory reset and start new,
That is the reason i have so many keys i do not know which one's is important and which one's no longer works.
Re: hellobox8
Anyway, I may be wrong in my observation because anytime I import keys I do netupdate ..could be that its the net update that is working for powervu...but "Tan...." works even without netupdate
Pionex2020
Re: hellobox8
All the keys are being transferred, but the hellobox does not duplicate keys that is why the count is lower.
- machteck
Re: hellobox8
No it will not duplicate you are right found that out by manually installing the keys the box 5 hd will not duplicate the keys ether.Pionex2020 wrote: ↑Mon Dec 09, 2019 10:52 pmAll the keys are being transferred, but the hellobox does not duplicate keys that is why the count is lower.
