May I ask the engineer which of the following files is the PLs code folder?
May I ask the engineer which of the following files is the PLS code folder? What tool can I use to open it without scrambling?
As the STB is a built-in multi-stream PLS code, the STB firmware file is missing two sets of PLS scodes, 11633 and 11669 of Taiwan ST-2 satellite. PLs code needs to be added, but I do not know which file is used to store PLs code. Does anyone other than the engineer know?
- Screenshot_20200807_102759.jpg (1.09 MiB) Viewed 5391 times
Re: May I ask the engineer which of the following files is the PLs code folder?
As the STB is a built-in multi-stream PLs code, the STB firmware file is missing two sets of PLs codes, 11633 and 11669 of Taiwan ST-2 satellite. PLs code needs to be added, but I do not know which file is used to store PLs code. Does anyone other than the engineer know?
Pls:
11633 H 30000,pls 260334;
11669 H 30000,pls 248232;
Sorry,this chip does not support pls code.
Hellobox8 does not support the input of PLS code.
We know that IR1 and IR2 are remote control codes. What are the others? What tool can I use to open it without confusing code?
yaya82
我看你多次反映这个88ku plsn问题官方都不愿意植入,应该是国内用户太少的原因。他觉得没必要去开发。
If you don't want to develop it, tell us how to do it. Do it ourselves
