May I ask the engineer which of the following files is the PLs code folder?
Post by 彩票游戏 » Fri Aug 07, 2020 2:28 am
May I ask the engineer which of the following files is the PLS code folder? What tool can I use to open it without scrambling?
As the STB is a built-in multi-stream PLS code, the STB firmware file is missing two sets of PLS scodes, 11633 and 11669 of Taiwan ST-2 satellite. PLs code needs to be added, but I do not know which file is used to store PLs code. Does anyone other than the engineer know?
Re: May I ask the engineer which of the following files is the PLs code folder?
Post by 彩票游戏 » Fri Aug 07, 2020 4:03 am
As the STB is a built-in multi-stream PLs code, the STB firmware file is missing two sets of PLs codes, 11633 and 11669 of Taiwan ST-2 satellite. PLs code needs to be added, but I do not know which file is used to store PLs code. Does anyone other than the engineer know?
Post by 彩票游戏 » Fri Aug 07, 2020 4:16 am
Pls:
11633 H 30000,pls 260334;
11669 H 30000,pls 248232;
Post by fenddick » Fri Aug 07, 2020 5:56 am
Pls:
Sorry,this chip does not support pls code.
Post by 彩票游戏 » Fri Aug 07, 2020 7:24 am
Pls:
It's impossible. You can accept all the Pls channels in foreign countries with this machine
Post by fenddick » Fri Aug 07, 2020 7:30 am
Pls:
Hellobox8 does not support the input of PLS code.
Post by 彩票游戏 » Fri Aug 07, 2020 9:15 am
Hellobox8It is true that you can receive multistream Pls channels from abroad
Post by 彩票游戏 » Sat Aug 08, 2020 2:25 pm
We know that IR1 and IR2 are remote control codes. What are the others? What tool can I use to open it without confusing code?
yaya82
Post by yaya82 » Sun Aug 09, 2020 2:47 am
我看你多次反映这个88ku plsn问题官方都不愿意植入,应该是国内用户太少的原因。他觉得没必要去开发。
Post by 彩票游戏 » Sun Aug 09, 2020 4:50 am
If you don't want to develop it, tell us how to do it. Do it ourselves
