Turn off the standby and turn on the remote control does not work
- tonsat
Help with Hellobox v8. Press the button to turn off the device with the remote to standby. The remote control is pressed, press it back does not work.
Re: Turn off the standby and turn on the remote control does not work
it's a problem that came up with the latest firmware, release 20200630 me and others had the same problem as you can read here: http://www.freedvb.com/viewtopic.php?f= ... 835#p24594
you need to reload the old firmware release 20200603 or a previous one like release 20200522
- tonsat
Yes sir thank you
