how to upgrade Hellobox V5 plus through RS232 serial port?
- DVBFinder
1. Copy bin file to a USB device and change to the file name to "hellobox _ V5 _plus.bin"
2. Insert the USB device to Hellobox V5 Plus Support and receiver
3. Connect Hellobox V5 plus with computer through RS232 cable
4. Run "WinSTBUpgrader.exe "on computer
5. Select and Open serial port
6. Click" download "page, select the config file " V5 _plus_8M.xml "
7. Click" Start "
8. Power on Hellobox V5 plus, and wait ...
After upgrading is done, Hellobox V5 plus will reboot automatically.
Please enjoy and download the tool RS232 here :
https://my.pcloud.com/publink/show?code ... CQs8yxQ6SX
7. Click" Start "
Please follow our Facebook Pages:
DVBFinder
DVBPlayer
Hellobox Electronics
						DVBFinder
DVBPlayer
				Shihab0068
Re: how to upgrade Hellobox V5 plus through RS232 serial port?
Hellobox v5plus.Softweyar upgrading the ded watis the new upgrading
				BABRA LUNGU
sir is it possible to use laptop
				ttvelu
Any possibility to upgrade thro' USB Pen drive?
				AZCoder
What does the cable look like?  I have a USB to RS232 cable that I can use with the program.  Is the cable a straight through or does it have to have data pins 3 & 4 reversed?  I cannot restore V5 Plus using this method.  Any additional information is welcome.  My  unit will not reboot after doing factory reset!!!
				sarkar
Hello.
Good Morning. There is any specifications for RS 232 cable ? Or any cable will work ?.
Thanks a lot.
Sarkar
Thanks a lot.
Sarkar
				AZCoder
I ended up getting a null modem adapter for the cable and that seemed to do the trick.  Otherwise it is a standard rs-232 straight through cable.
				suzon1986
I have followed those step but it doesn’t workDVBFinder wrote: ↑Sun Dec 23, 2018 2:18 am1. Copy bin file to a USB device and change to the file name to "hellobox _ V5 _plus.bin"
7. Click" Start "
Please follow that link what I was facing problem
https://www.facebook.com/photo.php?fbid ... =3&sfns=mo
I want a solution please
HELLO BOX 8
HELLO BOX 6
KOS GSKY V5
K5S Modern
FREESAT V7 COMBO
FREESAT V8 PRO 2
GTC 4K
GX6605S
TIGER T8 V2
STARSAT EXTREME 2000
DIGISAT 3232 UHD
OPEN BOX Z5
SOLID 6321 HEVC
ADLINK 9999 HD
DC BBS-1
						HELLO BOX 6
KOS GSKY V5
K5S Modern
FREESAT V7 COMBO
FREESAT V8 PRO 2
GTC 4K
GX6605S
TIGER T8 V2
DIGISAT 3232 UHD
OPEN BOX Z5
SOLID 6321 HEVC
ADLINK 9999 HD
DC BBS-1
				maxy
This method is Not working. USB Drive has the file but no matter what it says Unable to read "hellobox_V5_plus.bin"
Serial Port Opened
monitor start
download start
Please reboot the STB manually.
Change baudrate to 115200.
monitor stop
Sync Succeed.
Sending boot init...
Send boot init completed.
boot init run successfully.
SendClient.
Sending Client is complete.
Client is up.
Client Functionality is good.
uboot run successful
download successful!
monitor start
usb start;fatload usb 0 83000000 hellobox_V5_plus.bin;sf burn 83000000 0 800000;
(Re)start USB...
auto_detect_usb_port --- usb default sel port 1
port_sts0:0x00000803 port_sts1:0x0c000000
auto_detect_usb_port --- usb sel port 0
USB: usb_debug
need usb0 plug in....
usb0 device connect port status :0x1803
port0 reset down port status :0x8001205
ehci_hcd_init...
Register 10011 NbrPorts 1
USB EHCI 1.00
scanning bus for devices... 2 USB Device(s) found
scanning bus for storage devices... 2 Storage Device(s) found
scanning bus for ethernet devices... 0 Ethernet Device(s) found
reading hellobox_V5_plus.bin
** Unable to read "hellobox_V5_plus.bin" from usb 0:1 **
do_spi_flash_uboot_save offset[0] len[2d600000]
spi0 is already setup!!!
SF: spi flash status register: 0x00, 0x00
SPI: Detected EN25QH64A with erase size 64 KiB, total 8 MiB
						Serial Port Opened
monitor start
download start
monitor stop
Sync Succeed.
SendClient.
Client is up.
monitor start
(Re)start USB...
USB: usb_debug
ehci_hcd_init...
USB EHCI 1.00
Change to a Fat32 U disk to ensure that files are placed in the root directory (there are no other partitions)maxy wrote: ↑Sun Aug 18, 2019 5:57 pmThis method is Not working. USB Drive has the file but no matter what it says Unable to read "hellobox_V5_plus.bin"
Serial Port Opened
monitor start
download start
monitor stop
Sync Succeed.
SendClient.
Client is up.
monitor start
(Re)start USB...
USB: usb_debug
ehci_hcd_init...
USB EHCI 1.00
