Page 1 of 3
Biss api service is online
Posted: Mon Aug 31, 2020 7:29 am
by hellobox
API_URI :
Code: Select all
api_uri : https://service.freedvb.com/biss/${API_KEY}+${TS}+${API_SIGNATURE}
Example :
Code: Select all
https://service.freedvb.com/biss/00000000000000004741419a05d687e0c29a2cc3360a82db00ca03ad75cd379bd4fb105a877cb4635ff815db8fe3fc3f3f86dd32d4c02617376b07218c5816d668d1b23d97520fd52359813607a3ada2c872543103376382ad7793d8778e4d04ce133177abd5e1d0053445725e461ee045a5c23b0a0aef9622306f0af3d91c1c0dd581be9de63bc4c089a592ef6d3100045a0244340cba9c0c3d04e1a56baa1260a71b9e51c56e1f70dda5c6297602cdd4051ac95993a5fbfa2bfb85f6e3b42a168ce0964cc7bfb797390719
You can apply for an api key from FreeDVB without any fees.
Re: Biss api service is online
Posted: Fri Oct 30, 2020 8:08 am
by gregeric
With only two previous posts, I cannot send a PM yet. How can I obtain an api key? Can FreeDVB send one in PM to me please.
Edit: PMs are now unlocked with this third forum post
Posted: Wed Nov 04, 2020 8:08 pm
by signalq
Can you please also inform me how to request the API key? Thank you.
Posted: Fri Nov 13, 2020 8:46 pm
by Sysub
Good works
Posted: Fri Nov 20, 2020 2:50 am
by signalq
Thanks for your help. Can you please explain how to obtain the TS variable? Is it the crypt8? If so, the example TS is much bigger than a typical crypt8. Thank you.
Posted: Sat Nov 21, 2020 8:03 pm
by seefoo
I don't know if this is the proper method but I am applying for the API service. Please send the info I need. Thanks.
Posted: Sun Nov 29, 2020 2:46 pm
by gregeric
signalq wrote: ↑Fri Nov 20, 2020 2:50 am
Grab any TS packet, 188 bytes long, that is marked with the PUSI bit set in the 4 byte header. Sign it as described in the first post in this thread, and submit to the server. Response is inside a couple of seconds, either not found, or good key.
Posted: Tue Dec 01, 2020 1:54 am
by signalq
Thank you! It works for me.
Just some followup questions:
1. Does it matter what PID the packet is from Audio or Video?
2. Are there ever fake packets? If so, are their ways to detect them?
3. Does it matter mpeg2 vs. mpeg4?
Posted: Mon Dec 07, 2020 7:41 pm
by gregeric
@signalq - seems to make no difference whether the packet is audio/video, mpeg2/4 etc, but in all cases the packet should be one where the PUSI bit is set.
Posted: Fri Dec 18, 2020 1:48 pm
by rocam
I too am interested
