How does Hellobox 8 wifi work? It says no wifi connected.
Are there specific options to connect the box to my home wifi? Or i need an aditional wifi antenna connected to the box?
Re: How does Hellobox 8 wifi work? It says no wifi connected.
The box already has WiFi device,plz go to Menu->Network-Network Setting ,(wifi optiong)then press "green"button to search wifi,What does it show?
Thank you. It worked as explained.
Switch off and on from power button then box shows no wifi device.
No wifi device had found when you power off and on?rahulandyou wrote: ↑Thu Aug 22, 2019 8:05 amSwitch off and on from power button then box shows no wifi device.
Menu -network setting ,what's the wifi show?
