Audio through the AV OUT jack.
vustim
Hello. I connected the audio cable from the kit to the AV out connector, and found that the sound was transmitted mono, not stereo. two channels work. Through HDMI, everything is fine, audio is transmitted in stereo format. Dear users, help me figure out what the problem is: In the firmware or in my receiver. Dear firmware developers, if your defect is Soft, please correct.
Re: Audio through the AV OUT jack.
We'll check it.vustim wrote: ↑Sat Jun 27, 2020 9:02 pmHello. I connected the audio cable from the kit to the AV out connector, and found that the sound was transmitted mono, not stereo. two channels work. Through HDMI, everything is fine, audio is transmitted in stereo format. Dear users, help me figure out what the problem is: In the firmware or in my receiver. Dear firmware developers, if your defect is Soft, please correct.
The problem is in the electrical circuit itself (the manufacturer saved on several components). Instead of 2 audio channels, only one audio channel was used, and therefore, mono sound is present on the connection output of an analog signal.fenddick wrote: ↑Sun Jun 28, 2020 7:27 amWe'll check it.vustim wrote: ↑Sat Jun 27, 2020 9:02 pmHello. I connected the audio cable from the kit to the AV out connector, and found that the sound was transmitted mono, not stereo. two channels work. Through HDMI, everything is fine, audio is transmitted in stereo format. Dear users, help me figure out what the problem is: In the firmware or in my receiver. Dear firmware developers, if your defect is Soft, please correct.
I did the same test and I confirm that things seem to be so
I measured with a tester, there is electrical continuity between the left and right channel outputs, this means that the two channels are connected together...
I can't believe it, I want to think it's just a mistake and not a choice to save, save what?
FreeDVB, please give us an explanation, thanks
