Hellobox 8 firmware release 20200630
Post by fenddick » Thu Jul 02, 2020 6:14 am
  • Update uboot
  • Fix subtitle not save issue
  • Fix some bugs
Myworld
Re: Hellobox 8 firmware release 20200630
Post by Myworld » Thu Jul 02, 2020 8:47 am
how to cnvert this firmware to bin files
Myworld
Post by Myworld » Thu Jul 02, 2020 9:23 am
this firmware cannot download
Post by Cluster.One » Thu Jul 02, 2020 9:28 am
With this last release, after I turned it off with the remote control it no longer turns on and does not react to the remote control and the clock remains fixed on the time of the crime ... you have to unplug it ... tried several times...
reloading old firmware ...
Hellobox 8 old version
con queswta ultima versione, dopo averlo spento con il telecomando non si accende più non reagisce al telecomando e l'orologio rimane fisso sull'ora del delitto... bisogna staccare la spina...provato diverse volte...
ricarico vecchio firmware...
Post by Cluster.One » Thu Jul 02, 2020 10:47 am
it is already a .bin file, you have to unzip it
Post by Garuda_ID » Thu Jul 02, 2020 10:53 am
Thank's
scollrocker
Post by scollrocker » Thu Jul 02, 2020 1:42 pm
SAME HERE! have many bug this box
Post by edzus1 » Thu Jul 02, 2020 5:06 pm
Hey.
Thank you for adding a full 7 day EPG.
But there are bugs in the firmware:
1 When you enter standby mode, Hellobox 8 NEW freezes and in order to exit out of freezes Hellobox 8 NEW, reboot is required (power off)
2. If want to record the program from the EPG using the green button, TIMer setting. Noticed 2 errors:
2.1 the setting of the engine location is lost. USALS -> Set location
2.2 there are 21 timers with the choice OFF or ONCE
when checking the list of timers there are no 21 timers. (this problem is mentioned here http://www.freedvb.com/viewtopic.php?f=25&t=18836 there is the screen itself 21 timers
I tested several firmware:
Hellobox8_20190725
Hellobox8_20191031
Hellobox8_20200410
Hellobox8_20200522
The result is 21 timers everywhere, but there are no 21 timers in the timer list )
Due to 1 error when switching to standby mode, the new firmware 20200630 cannot be used.
Correct these errors so that you can update Hellobox 8 NEW.
P.S.
I had to go back to the created backup that I created before checking firmware 20200630
Myworld
Post by Myworld » Thu Jul 02, 2020 5:29 pm
O.m.g...this firmware still problem...ccam not work properly...youtube also can't open & some data missing please fix immediately...i frustrated becouse i have 5 receiver problem...please...fix immediately tq💆💆💆
zawaung
Post by zawaung » Fri Jul 03, 2020 12:08 am
Thanks. On this firmware Epg show fully 7 day. But there is still errors. Time is still incorrect and it cannot be reopen from the remote . When I off the from the remote the box crush and time stopped. Please fix this error. TQ :) :) :)
Locked
