DiseqC Problems
myhellobox8
DiseqC Problems
Post by myhellobox8 » Wed Aug 05, 2020 9:05 pm
Hi, Anyone to help please, I am attached 4 satellite dishes via DiseqC
All the Ports of DiseqC are correctly configured but, At the time of scanning only one dish channels for all satellites
Re: DiseqC Problems
Post by Yawwilson » Thu Aug 06, 2020 4:59 am
I suggest you remove the diseqc switch, scan the various satellite separately after that connect the diseqc and allocate the ports to the different satellites.
Hellobox8
Re: DiseqC Problems
Post by Hellobox8 » Thu Aug 06, 2020 8:38 am
It is my advice to change port number as per satellite has to be connected
myhellobox8
Re: DiseqC Problems
Post by myhellobox8 » Fri Aug 14, 2020 3:08 pm
Dear Bro, Thanks but didnt work, It seems issue is with Board Components
myhellobox8
Re: DiseqC Problems
Hellobox8
Re: DiseqC Problems
Post by Hellobox8 » Fri Aug 14, 2020 4:51 pm
Set as per diseqc switch port and set top port both are should be equal matched
Re: DiseqC Problems
Post by edzus1 » Fri Aug 14, 2020 7:40 pm
Do you have Diseqc working?
Here is an example video of how to check whether Disqc is working.
https://www.youtube.com/watch?v=Vh6AxlJfbxE
The video in Russian (everything can be understood and not knowing the language) describes in detail how Disqc will check. To check, you need a piece of cable with a connector and 2 components : any LED + 1 kΩ resistor (I would advise you to make 4 test cables with LEDs to immediately see which port is working)
https://www.youtube.com/watch?v=b0s09JkSWOg
What Disqc you configured in the settings - Disqc 1.0 or Disqc 1.1 ?
Disqc 1.0 is designed for 4-port Disqc or 2-port Disqc
Disqc 1.1 is designed for 8 port Disqc
udbghdto
Re: DiseqC Problems
Post by udbghdto » Sat Aug 15, 2020 11:53 am
DiseqC 1.0
1: 100.5E (5150-5750)
2: 166.0E (5150-5750)
Two ports are no problem. When using 100.E, if there is no signal from 166.E, the 100.5E cable must be disconnected. Can't switch anyway
Re: DiseqC Problems
Post by Yawwilson » Sat Aug 15, 2020 12:28 pm
Well, bro I connect all 4 Lnbs to my diseqc and it works fine.. however if you want to scan with Dvbplayer, don't change the diseqc settings already allocated by the Hellobox 8..
Hellobox8
Re: DiseqC Problems
Post by Hellobox8 » Thu Oct 15, 2020 7:08 am
See you tube how to configuration of disqc swtich
