Page 1 of 2
Serial port upgrade tool
Posted: Mon Aug 02, 2021 3:22 am
Support Hellobox 8,k6,Hellobox 6Combo
Please download all 3 files.
Re: Serial port upgrade tool
Posted: Mon Aug 02, 2021 5:19 am
by Arbourboateng
Thanks you...
Posted: Mon Aug 02, 2021 2:42 pm
by Mahdi2000
Thennnnnksssssss
Posted: Tue Aug 03, 2021 9:42 am
by Yawwilson
Warmest regards Fenddick(mod).. and many thanks for the hard work..
Anyway, there is no manual/instructions regards to the software posted...and to be .more curious, is it for a special software yet to be posted?
Posted: Tue Aug 03, 2021 1:16 pm
by formula
Serial port opened
reboot the STB Manualy
SYNC Success!
Change baudrate to 115200
sending boot init...
send boot init completed.
boot init run failed.
upgrade return
Please what the meaning of this msg?!
(the red lamp run every time)!!
Posted: Tue Aug 03, 2021 10:42 pm
by Yawwilson
Well folks, the Hellobox 8 has no rs232(serial port)..so can a serial rs 232(9pin) to usb adapter be used... will it work well?
Posted: Thu Aug 05, 2021 6:01 am
Serial port opened
SYNC Success!
upgrade return
Plz plugin&out the serial port and try again
Posted: Thu Aug 05, 2021 4:40 pm
by formula
Serial port opened
SYNC Success!
upgrade return
I've done this 35 times, same msg, and the red light keeps on.
Posted: Fri Aug 06, 2021 2:20 pm
by Yawwilson
Serial port opened
SYNC Success!
upgrade return
My dear friend, which cable did you use and how is the connection from the computer to the box?
Posted: Sat Oct 09, 2021 5:38 pm
by Hawker
I am also using Db9 cross cable working on other boxes but can't revive my Hellobox 8. Only red Led light showing. Different USB disks still not working.
