Release of Hellobox CS8001 ROM New version 20210201
pritamcharan
Re: Release of Hellobox CS8001 ROM New version 20210201
Post by pritamcharan » Tue Feb 09, 2021 4:21 pm
even after using Hello Merger Tool v1.4 , IR remote not working., PANEL Buttons working but IR Remote not working.
broadway
Post by broadway » Sun Feb 14, 2021 12:54 pm
Solid 8181 uses the newer cs8051 chip which supports h265 codec
This firmware is meant for the older cs8001 chip which supports till h264 codec
dlollyboi
Post by dlollyboi » Fri Feb 26, 2021 6:07 pm
It is not h.265 compliant. For 8mb chip use rs232 to flash
cyberworld23
Post by cyberworld23 » Tue Mar 02, 2021 3:39 am
Garuda_ID wrote:
Tue Feb 02, 2021 6:09 am
Tue Feb 02, 2021 5:57 am
New Firmware Release:
  • fix channel list bug
  • update information(sj)
  • update youtube
  • update scam+ version 2.1
I have koqit u2 red version with montage cs8001 chipset where the original firmware size 8192Mb. My question is..can i upgrade that box with this firmware ? should i rename the file name to auto_burn.fac ?
cyberworld23
Post by cyberworld23 » Fri Mar 05, 2021 1:33 am
ardasa wrote:
Tue Mar 02, 2021 6:40 am
I also have koqit u2 red.update in auto_burn.fac.
Does it succes? what about remote control, still working normal bro?
joey67
Post by joey67 » Fri Mar 05, 2021 3:30 pm
thanks, working good in A3 & A6 Montage receivers, only problem is the scam it is not working most of the time
ceec
Post by ceec » Sat Mar 06, 2021 5:53 am
ardasa wrote:
Fri Mar 05, 2021 7:27 am
no, the remote didn't work.I replaced ir1 and ir2 with CCTEdit program. Now the remote works.
here for the red koqit u2 with a working remote.
thank working good for me its better than orginal software
broadway
Post by broadway » Sat Mar 06, 2021 8:47 am
Share cctedit download link
Also, how do you replace a ir1/ir2 file that is 72k with 128k?
broadway
Post by broadway » Sat Mar 06, 2021 6:02 pm
I tried the software you shared
It replaced the ir files successfully but only works with 128k files.
joey67
Post by joey67 » Sun Mar 07, 2021 6:59 am
Scam is working now smoothly all channels opening, this software is great thanks to all devlopers
