Hellobox V5 firmware release 20210329A
joey67
Re: Hellobox V5 firmware release 20210329A
Post by joey67 » Fri Apr 23, 2021 12:16 pm
Preiz wrote:
Fri Apr 23, 2021 12:11 pm
Still telling me unsupported. This is what I did, I downloaded the new updated firmware and rename it as autoburn_fac.bin saved it and copy to pendrive then I connect it to my hellobox v5hd.i switched it off and on then go to USB upgrade to run d firmware but still telling me unsupported.
it's auto_burn.fac, Change bin file to auto_burn.fac Automatic upgrade. Put it in pendrive(only this file should be in pendrive) and attach to usb port of reciever and turn on, automatic upgrade will begin. after upgrade complete remove pendrive
Preiz
Post by Preiz » Fri Apr 23, 2021 12:33 pm
I've rename d bin file with auto_burn.fac, switched off and on my box but not showing anything. It box just show red light and on display on d box screen.
joey67
Post by joey67 » Fri Apr 23, 2021 12:48 pm
Auto upgrade
Turn off the Hellobox V5 power
Rename the firmware to auto_burn.fac, and place it in the USB root directory
Insert the USB into Hellobox V5 , and turn on the power
The box will display "USB" for about 5~10 seconds if the USB is detected correctly, and the upgrade process will start automatically. The panel will show the progress
When finished, "FFFF" will be displayed.
REMOVE THE USB AND DELETE THE auto_burn.fac FILE IN USB!!!
Turn off and turn on the box, it will be back
Does it boot, what is showing on the tv screen, which version have you installed before upgrading
Preiz
Post by Preiz » Fri Apr 23, 2021 12:52 pm
It just show red light and write On. Not showing anything on TV.
Preiz
Post by Preiz » Fri Apr 23, 2021 12:54 pm
I installed version 2.0 on it
joey67
Post by joey67 » Fri Apr 23, 2021 3:44 pm
your box is dead, i assume you installed unofficial 2.0 bin from somewhere in your box, you can recover your box using rs232 from computer.
Preiz
Post by Preiz » Fri Apr 23, 2021 6:22 pm
Can you give me guidelines on how to do using computer? Pls help me
fenddickk
Post by fenddickk » Sat Apr 24, 2021 3:46 pm
working good
espaun206
Re: Hellobox 6(V5) firmware release 20210329A
Post by espaun206 » Sun Apr 25, 2021 3:13 am
Fri Apr 23, 2021 8:39 am
fenddickk wrote:
Fri Apr 23, 2021 6:02 am
Thu Apr 22, 2021 8:35 am
This is the first firmware relase for Hellobox 6(v5), if you have a Hellobox V5, you can upgrade with this new-designed firmware.
Please keep Upgrade mode(ALL) for the first time upgrading to Hellobox V5....If you upgrade other modes, it will crash.
  • which version Scam is present in this version?
    can i update channel list from previous vesion DB?
    Will it wipe off my current Scam validity?
    please give answers someone
Does updating my Hellobox V5 box with this new firmware will change my box into Hellobox 6?
No, it is still Hellobox V5. Please select upgrade mode(all )when upgrading
mode(all ) Will channels already saved be deleted, or how to make a backup copy of these?
fenddickk
Post by fenddickk » Sun Apr 25, 2021 2:37 pm
Yes! it will be deleted, to backup goto update option and save dump file in pendrive.
