Autobiss is also not working on satellites covering Brazil, before it worked normally.
Hellobox 6 firmware release 20210521A
Re: Hellobox 6 firmware release 20210521A
Satélites: 70W C,75W C,65W C,43W C,40.5W C,22W C,58W C,61W Ku,63W Ku,75W Ku,74W Ku,67W Ku,65W kU,3W C.
Aparelho: Hellobox 6.
País: Brasil
País: Brasil
Auto biss does not work, on previous firmware versions either.
The DVB finder works, it finds the key, which must be entered manually. Please solve the problem.
Equipe Hellobox,por favor responda porque o autobiss não funciona no hellobox 6 e se esse aparelho abrirá 4:2:2.
Por favor responda,muito obrigado.
País: Brasil
País: Brasil
- wahyu d.w
viewed thirty times, but no answer yet. around next Sunday, my hellobox 6 arrives. it's hard to re-scan, fill in the satellite list, and sort the channel list on the new receiver. about more than 40 satellites from 172° E ~ 45° E
- Screenshot_2021-06-03-07-26-32-426_com.opera.browser.jpg (675.89 KiB) Viewed 4247 times
Auto Biss not working for 78.5e 100.5e
عزيزي لا يفتح معي
Do Not Auto Roll Biss. .Please Fix. .
Mgcamd crash using private iks, not opening channels.
Audio is disabled when changing audio tracks. It is deactivated until you change channels.
- cybersizu
Autobisskey does not work.
- gxu
H6 autobiss works now.
Sorry for the inconvenience.
