Post
by car mel » Mon Apr 19, 2021 2:26 pm
Hi Hellobox team:
@fenddick
@gxu
@Joey
Here is a TS Record of a TP frequency in America that any time a blindscan or autoscan is run make the Hellobox to get stuck or freeze and does not allow to finish the scanning. Can you take a look and analyzed to see if you can fix firmware to allow scanning? Thanks
This is in America region Ku Band Galaxy 17 91.0 west TP frequency 11913 V 2000
Code: Select all
https://www.mediafire.com/file/4106ne5u9emr4l9/11913-V-2000-2021-04-19_10-03-01.rar/file
SAM I 10'- Dreambox DM800HDse-Hellobox-GTMedia
elvv
Post
by elvv » Tue Apr 20, 2021 2:46 pm
Same problem 58W Fec 3800H sym 8200 when It goes blind scam.
Post
by car mel » Tue Apr 20, 2021 6:42 pm
elvv wrote: ↑Tue Apr 20, 2021 2:46 pm
Do a 5-8 minutes TS record and upload here so the Hellobox team can take a look at.
Post
by gxu » Thu Apr 22, 2021 9:01 am
car mel wrote: ↑Mon Apr 19, 2021 2:26 pm
Hi Hellobox team:
@fenddick
@gxu
@Joey
Code: Select all
I have analyzed the stream you uploaded, this stream is full of errors, not a valid ts stream.
If you are sure this TP is DVB stream, would you please record a stream again?
Thanks,
Post
by car mel » Thu Apr 22, 2021 3:07 pm
gxu wrote: ↑Thu Apr 22, 2021 9:01 am
Hi Hellobox team:
@fenddick
@gxu
@Joey
Code: Select all
Thanks,
Ok, Thanks for the feedback. I will do a new one using a Hellobox model and upload new file. Thanks
Post
by car mel » Thu Apr 22, 2021 3:16 pm
Hi Hellobox team:
@fenddick
@gxu
@Joey
Code: Select all
Thanks,
@gxu
Here is a new 8 minutes TS record using a Hellobox model. This is a non ussual TP with some radio stations which make the units get stuck. Please advice, Thanks
Code: Select all
https://www.mediafire.com/file/zudqzqjdco5xrut/11912-V-1999-2021-04-22+10-01-42.ts/file
Post
by fenddick » Sun Apr 25, 2021 6:05 am
Hi Hellobox team:
@fenddick
@gxu
@Joey
Code: Select all
Try this one.
- H6_20210425_cstm_h6_vision_128m_A.rar
- (3.82 MiB) Downloaded 313 times
Post
by car mel » Sun Apr 25, 2021 4:26 pm
fenddick wrote: ↑Sun Apr 25, 2021 6:05 am
Hi Hellobox team:
@fenddick
@gxu
@Joey
Code: Select all
Try this one.
Excellent!! Fixed!! Thanks!!! Good Job!!!
