Hellobox V5 firmware release 20190311A
Re: Hellobox V5 firmware release 20190311A
Thank you for the correct address. I had an extra underscore at the end. The remainder was correct - just my eyesight not reading the uppercase V correctly. So now I have only question 1.
When I click on Start, I get a choice:
Local: 20190311-113235
Latest: 20181225-151321
download the latest one?
Yes No
The No is preselected
I tried selecting the 20181225 version and as expected I lost anything that was encrypted. All was restored again after a usb upgrade. Is this fixable?
Yes No
Now the updated version of the network is old, and the new version will always be updated in this section.polly wrote: ↑Wed Mar 20, 2019 9:48 amThank you for the correct address. I had an extra underscore at the end. The remainder was correct - just my eyesight not reading the uppercase V correctly. So now I have only question 1.
Yes No
If u want to save userdb(channel,keys,cccam...),u can choose software only from the USB upgrade menu to upgrade.
Ok many thanks, i won't bother with the network anymore. Also thanks for a great forum
Cheers
Cheers
Will the network ever be updated so we can update from network once again ??fenddick wrote: ↑Thu Mar 21, 2019 3:23 amNow the updated version of the network is old, and the new version will always be updated in this section.polly wrote: ↑Wed Mar 20, 2019 9:48 amThank you for the correct address. I had an extra underscore at the end. The remainder was correct - just my eyesight not reading the uppercase V correctly. So now I have only question 1.
Yes No
Waiting for important updates!iggy57 wrote: ↑Thu Mar 21, 2019 1:40 pmWill the network ever be updated so we can update from network once again ??fenddick wrote: ↑Thu Mar 21, 2019 3:23 amNow the updated version of the network is old, and the new version will always be updated in this section.polly wrote: ↑Wed Mar 20, 2019 9:48 amThank you for the correct address. I had an extra underscore at the end. The remainder was correct - just my eyesight not reading the uppercase V correctly. So now I have only question 1.
Yes No
Frenddick
" Waiting for important updates!"
Can you explain a little more about your answer to
"Will the network ever be updated so we can update from network once again ??
i want to next update vline cam option ok
remember that..
remember that..
