Are you saying that Hellobox can accommodate gx6605s software? If so which Hellobox model?fenddick wrote: βTue Nov 10, 2020 2:18 amPlz wait.mhmohamed1998 wrote: βTue Nov 10, 2020 12:38 amAsap i need GX6605S firmware![]()
I have KOQIT box.that box also include gx6605s chip set.
I want try.
Gx6605s need firmware
Re: Gx6605s need firmware
Hello, I have the Hellobox 8. Does this device also work with Gx6605s ROM? If yes, what are the differences and were are the advantages. Is there somewhere a description or manual available? Does it simply has tho be flashed by USB? Thanks
- wahyu d.w
awokwokwokwok
ngga punya rx nya ,mbah
- wahyu d.w
keponakan-ku.... you should have to buy it first. or nunggu lungsuran user ganti kapisen, keponakan-ku
I want try.
Thanks guys for your help,
Sitzme, im doing that right now, just running gcode and moving it close to the switches to home, but none then none of the creation workshop controls work. Which is fine for testing but Id like to get something figured out.
Finhead, Thank you for all your help. I really appreciate it. I just have no idea what I need to do with that code. The muve1 firmware doesnt work with my machine, nothing moves. Like I said, I am really bad with software and really have no idea where to even start. Also, I really dont have the time to learn it right now.
So Im hoping you could help me with my firmware? Id like to do exactly as you described. Can I send you my firmware for you to add the peel move to it?
Plz send me your firmware.JadenImmiz wrote: βWed Nov 18, 2020 7:44 pmThanks guys for your help,
