try this version, problem fixed. no need to disable cw checkAhamed NIFRI wrote: ↑Tue Dec 29, 2020 12:07 pmVideocon (88E) working only after off CW check.
But this time all sat are freezing ( mostly cline opening channels 45E,88E and 108.2E)
But normally all sat working perfectly ON after CW check
SO can't watch 88E and 108.2E at the same time
So please fix this issue immediately
Note:- this issue mostly have cline user
Hellobox 6 firmware release 20201228
Re: Hellobox 6 firmware release 20201228
Yes, it's correctgxu wrote: ↑Wed Dec 30, 2020 2:32 amtry this version, problem fixed. no need to disable cw checkAhamed NIFRI wrote: ↑Tue Dec 29, 2020 12:07 pmVideocon (88E) working only after off CW check.
Now perfectly working 108.2E and 45E but 88E freezing 2s to 2s
Can't watch 88E
Every time to time freez
Sir, the update will work on V5 plus if yes then kindly update the procedure .
Regards.
Regards.
Regards.
Regards.
After few days testing I have found CA Expansion Key Edit space limited to 600 quantity. Loading a Softcam with more than that will be cut to 600. After that and without room on memory the Auto Biss on new channels will not work not posible to add it. Please increase size of maximum keys to store. Thanks
It did not open 3966 H tp 43.1w AE10CAmericas & Europe auto PV.
helloboxv5 plus uydu alıcısına usbden yazılım atarken elektirikler kesildi şimdi hiç açılmıyor hiç bir ışığı yanmıyor güç kaynağını değişdirdim sonuç aynı ne yapmam gerekir
Hi fenddick,
Now SCAM+ has become terrible. 45edialog, 108e and 88e freezing too much these days. And theyare focusing on 108e which freezes every few secs instead of 88e which is relatevly smooth.
Pleasefocus on hellobox buyers and improve the speed, coverage and stability of scam+ on 45e and 88e atleaste for Sri lankan buyers.
Why still not respond for the adminAhamed NIFRI wrote: ↑Wed Dec 30, 2020 3:40 amYes, it's correctgxu wrote: ↑Wed Dec 30, 2020 2:32 amtry this version, problem fixed. no need to disable cw checkAhamed NIFRI wrote: ↑Tue Dec 29, 2020 12:07 pmVideocon (88E) working only after off CW check.
Can't watch 88E
Can't watch 88E
2s to 2s freezing
