Hellobox 8 upgrade introduction
Re: Hellobox 8 upgrade introduction
hi master! how to give hellobox8 rs232 usb update file name?
Features: Up to 8000 channels
Full memory with only 4250
as mentioned in the instruction:Naylinn2019 wrote: ↑Fri Aug 09, 2019 6:32 pmhi master! how to give hellobox8 rs232 usb update file name?
"Please refer to readme_upgrade.jpg/readme_download.jpg for hellobox8_upg usage."
Download the tool, and check the picture readme_upgrade.jpg/readme_download.jpg in the tool directory, you will find the detail.
Maybe RS232 cable in wrong order. GND to GND, 2RX to 3TX and 3TX to 2RX.
I try to use RS232 upgrade but no work. Maybe CPU crash
But you use a PC with a real RS 232 port or you use an RS232 to USB adapter? and if you used a PC with a real rs 232 port did you use a normal or nullmodem rs 232 cable to connect to rs 232 femaleplug to rs232 male to 3 pin adapter? https://en.wikipedia.org/wiki/Null_modem
choosing the wrong cable is easy, and for information you use Windows7 or Windows 10 ?
thank you very much!i need .
Serial Port Opened
reboot the STB manuallySYNC Success!
download start
Change baudrate to 115200.
Sending boot init...
Send boot init completed.
boot init run failed.
download failed!
m_download_thrd is stop!m_sp_mnt_thrd is stop!
help me !!!
download start
download failed!
help me !!!
- chxll
Life is not video game, you only get one chance.
mi buen diseñador, se podran hacer estos mismos pasos al actualizar a un hellobox v7 normal a un v8? en caso de que no me podria aclarar esta duda de que si se puede actualizar o no ala version v8 por favor.
