HelloMenu_GUI V1.3 release
Re: HelloMenu_GUI V1.1 release
hi, when do you fix the clock? the tuner sat not is very sensitive
Please Upload a official video for Hellomenu gui. You can make videos for eash menu, ex: block, thems, fonts, string, logo etc.
It's will helpful for me
Re: HelloMenu_GUI V1.3 release
hey ,
I began to translate the GUI to the HEBREW langauge as the 18 number of th languages and saved it as "file string_18.txt" and follow all the instructions and import as instructed ,but the system does not "see" this file.
I also tried to save the file as file string_1.txt - and imprt it as instructed - also the system see only an english language.
what i did wrong?
TNX
what i did wrong?
TNX
To export all strings, you need to download the font library of the language and name it FONT_1.ttf , then translate the string to be replaced into the language you want, and rename it to string_ 2.txt , put them(FONT_1.ttf,string_ 2.txt) in the same folder, import it together, and set the language to default.ILuser wrote: ↑Thu Jul 23, 2020 3:01 pmhey ,
what i did wrong?
TNX
thank you for your answer and explanations , i did exectly as you said and the problem solved .
when i will finish translate all the menus and sentences i can send it to you for uploadind it on the next upgraded version ,if you would like that.
thanks again
thanks again
What are the other items of the administrator? What software is used to open it after exporting? Thank you very much!
