- Update Youtube&Youporn
Hellobox 8 firmware release 20200522
- Hellobox8_20200522.rar
- (4.5 MiB) Downloaded 739 times
Re: Hellobox 8 firmware release 20200522
Hellobox 8_2020/05/22_chinese firmware
Chinese firmware also has English menu, welcome to download
- h8-0522中文固件.zip
- (5.13 MiB) Downloaded 461 times
Fix 8612
Fix 8612
LIVE list disappeared with this update
Isn' t problem to update: LIVE don't work also with the previous version.
Now LIVE it' ok, but not Youtube
There are errors in the programming
1. Time accuracy:
The watch is in standby mode. In 1 hour, the watch is ten minutes behind; in 11 hours, the watch is already 2 hours behind.
2. From the execution of the timer program.
Hellobox 8 New may turn on, may not turn on by timer. According to the timer program, the specified channel or the channel that was during the transition to standby mode will turn on. When turning off by the timer, the receiver may turn off or continue to show the same channel or transmit to that channel which was before executing the timer program.
1. Time accuracy:
Re: Please help / Hellobox 8 firmware release 20200522
Download the old software and rename it to “auto_burn.fac”,then insert it into the STB,restart the STB box until the panel shows FFFF.
Remember to delete this file, otherwise it will be upgraded all the time
edzus1 wrote: ↑Fri May 22, 2020 8:15 pmThere are errors in the programming
1. Time accuracy:
About the timer work has already been raised on the forum http://www.freedvb.com/viewtopic.php?f=25&t=18400
The problem is still not fixed.
