Hello Administration
It is really time to move on and update Hellobox units to allow to make it own powervu autoroll using AU EMM keys either embedded to the firmware or using the softcam.key file loaded by users. Constant EMM key changes or becoming expired make sometimes the on line AU autoroll obsolete. Keeping the server updated worldwide requires a lot of times. It will take time for users around the world to record the updated stream and send to persons in charge to run the new algorithm and load it to server. So it is the time to move on and open this opportunity to users and make the Hellobox competitive with others in the market.
Regards, Greetings
Time to update
Time to update
Re: Time to update
Thank you for your advicecar mel wrote: ↑Mon Jun 29, 2020 10:56 pmHello Administration
Regards, Greetings
