Abertis 30W
Abertis 30W
hello abertis 30W channels do not appear in the search solution please
Re: Abertis 30W
The issue has been talk to the programmers already and they are doing everything to solved Abertis dtt channels not appearing when you scan the frequencies... It's good you highlight the issue though let us be patient they will come with the solution eventuallyhackintosh wrote: ↑Fri Mar 05, 2021 11:34 pmhello abertis 30W channels do not appear in the search solution please
Re: Abertis 30W
Do we have a chance to watch Abertis channels on 30w on H8 decoder one day because it's seems all the effort has been negative for now , can you look more on that issues for us?
Re: Abertis 30W
Mr fenddick , Gxu and hellobox...great programmers here there is an issue that has been raised by most of the members here concerning Abertis dtt channels on moon 30w hispasat for a long time so here is the issue
the decoder has the signal alright but if you scan it doesn't bring the abertis channels to the receiver and its surprise that some of the cheapest decoder are viewing it while powerful receiver like hellobox cannot bring the channels down... Note if you like I can give you some of the receivers firmware that brings abertis dtt channels to study through your PM if you're interested to help solve this issue that has been talk for almost a year and half. Hopefully this time we can get the solution from you. Thanks
Re: Abertis 30W
Not only that, there is more!Arbourboateng wrote: ↑Wed Nov 17, 2021 3:06 amMr fenddick , Gxu and hellobox...great programmers here there is an issue that has been raised by most of the members here concerning Abertis dtt channels on moon 30w hispasat for a long time so here is the issue
BBC satback on 27.5°W
Greek channels on Hellasat 39°E
Even the Greek channels on Hellasat 39°E encoded in biss are not seen, channels are regularly tuned and memorized but are not seen.
With other cheap setopbox you can see them...
These are the frequencies involved:
Hellasat 39°E
12224 H 13381 3/4
12242 H 13381 3/4
ERT1 HD ERT2 HD ERT3 HD ERT1 SD ERT2 SD
Another thing of the many that has never been fixed is the impossibility of making long recordings...
