With the decoder in standby mode , timer scheduled recordings sometimes work, sometimes not... more no than yes (even if I inserts all the right settings and the and the clock is is Ok...)
With the decoder On, timer scheduled recordings seem to work well
If I program Timer and then leave the decoder in standby mode Hellobox 8 turns on at the scheduled time then a sign appears with the words: go to standby in 15 sec. and does not record anything... (even if I inserts all the right settings and the clock is is Ok...)
Leaving the decoder turned on is a useless power consumption...
All decoders I own start scheduled recordings from standby...
Is it possible to make scheduled recordings work even if Hellobox 8 is left on standby?
does it also happen to someone else?
Timer scheduled recordings sometimes work, sometimes not!
Re: Timer scheduled recordings sometimes work, sometimes not!
We'll check it.Cluster.One wrote: ↑Sat Aug 31, 2019 4:53 pmWith the decoder in standby mode , timer scheduled recordings sometimes work, sometimes not... more no than yes (even if I inserts all the right settings and the and the clock is is Ok...)
Khalangas
And the time in a display, once the decoder is off it slack down.
