Release HelloMerger V1.4
- Joey
Both support Hellobox CS8001 & GX6605S merge ir panel.
Max support 2 ir on CS8001.
If ir not work,change "User Code Revert"
try again.
try again.
- HelloMergerV1.4.rar
- (5.08 MiB) Downloaded 8143 times
Re: Release HelloMerger V1.4
thanks so much friend
Terima kasih
Good job
Tried Hello merger v1.4 with cs8001
It works when importing panel buttons
Importing for remote control doesn't work. Tried with and without tick mark(user revert code)
Remote pairing not working panel and leds pairs pls fix this issue.
My box has remote codes of 72 bytes each(ir1 and ir2) and Hellobox cs8001 firmware has 128 bytes of remote codes. I think that's the reason why my remote is not pairing through hellomerger 1.4. right now I am using smart rcu to pair a remote but many features like change audio,epg,livetv recording does not work. So developers pls sort out this pairing issue of hellomerger in next release. Thanks for this Hellobox cs8001 firmware Hellobox team.
Yesabhaysingh2009 wrote: ↑Sun Feb 21, 2021 10:41 amMy box has remote codes of 72 bytes each(ir1 and ir2) and Hellobox cs8001 firmware has 128 bytes of remote codes.
Partition sizes of hellobox firmware is different than existing OEM firmwares that's why ir1 editing(remote) is faulty. Ir2 editing(front panel buttons) working properly as far as I know.
Dear team,
Thanks for nice release...
pls inform how to configure lock signal led & standby led on front panel in cs8001 firmwares.
Thanks in advance
Sandeep
Thanks in advance
Sandeep
