Hellobox V5 firmware release 20210329A
This is the first firmware relase for v5, if you have a Hellobox V5, you can upgrade with this new-designed firmware.
Please keep Upgrade mode(ALL) for the first time upgrading to Hellobox V5....If you upgrade other modes, it will crash.
- k5_20210329_cstm_hellobox_classical_64m_A.rar
- (3.35 MiB) Downloaded 32523 times
Re: Hellobox 6(V5) firmware release 20210329A
amazing its cool
can this use multistream?
sat2ip missing please do something about
Thank You!!!
Thanks for the new firmware for hellobox v5, everything working great, Scam 2.1, no freezing playing smooth,
Thanks, for the new update
No, it is still Hellobox V5. Please select upgrade mode(all )when upgradingfenddickk wrote: ↑Fri Apr 23, 2021 6:02 am
- which version Scam is present in this version?
can i update channel list from previous vesion DB?
Will it wipe off my current Scam validity?
please give answers someone
Does updating my Hellobox V5 box with this new firmware will change my box into Hellobox 6?
Re: Hellobox V5 firmware release 20210329A
Hi, I tried to update the new firmware but it is telling unsupported. Pls help, I noticed that ever since I've upgraded to scam+ version 2.0 everything on my decoder change, and I can't go back to the original factory background and settings. Please help
Still telling me unsupported. This is what I did, I downloaded the new updated firmware and rename it as autoburn_fac.bin saved it and copy to pendrive then I connect it to my hellobox v5hd.i switched it off and on then go to USB upgrade to run d firmware but still telling me unsupported.
