Release of Hellobox GX6605S ROM New version 20210129
Re: Release of Hellobox GX6605S ROM New version 20210129
Great work hello box team
When we downgrade this software with original dump .... After that I unable to upgrade with any firmware/hellobox firmware...By usb.
.please give the solution...
Sir,
Not modified anything but this one has restart bug as box get turn off automatically after some time and when turn on all data get erased previous release which has only 7601 wifi has no issue if possible please release 7601 and 5370 firmware independently keep UP this community
Thank You
Thank You
Joey wrote: ↑Fri Jan 29, 2021 2:53 pmDO NOT try modify anything except HelloMerger tool supported.pritamcharan wrote: ↑Fri Jan 29, 2021 7:58 amOne Problem Found.
Box automatically goes OFF and when turn on , it resets itself.
All user data erased
Happend 3-4 times
- Joey
Great jop thanks for the latest update
thank you so much.....
Would you please uninstall dvb finder and add a more useful application? Add the QR code only for scam, the software would be better
same thing happened to me. only solution is to completly erase the flash rom and rewrite it with new fw.Paras arya wrote: ↑Sat Jan 30, 2021 3:10 amWhen we downgrade this software with original dump .... After that I unable to upgrade with any firmware/hellobox firmware...By usb.
- maxx
Did you use full dump file to upgrade the users data?
