Hellobox 8 firmware release 20210414A
arunkj
Re: Hellobox 8 firmware release 20210414A
Post by arunkj » Mon Apr 19, 2021 3:35 pm
Thanks sir one doubt nss 12 57*e ku band east africa beam one tp 10985 H 45000 full channels not work on dvb player apk but working good this tp on set top box some channels no sound
Will this problem go away if I install this software?
Post by Yawwilson » Mon Apr 19, 2021 3:44 pm
@Fenddick!.. could you explain how the stream out works on Hellobox 8?
Post by Cluster.One » Wed Apr 21, 2021 1:59 pm
edzus1 wrote:
Thu Apr 15, 2021 5:16 pm
A question for programmers and also developers.
When will the plurality of errors be fixed that are present in the firmware for Hellobox 8?
I was creating a separate topic in the section about Hellobox 8
here http://www.freedvb.com/viewtopic.php?f=25&t=19128
I don’t see any sense for updating to this new firmware 20210414A Reason: none of the multiple errors that are present in the firmware has not been fixed:
1. PVR is a long record that exceeds more than 4 GB (the recording time is reduced after cutting off the first 4 GB, after the creation of the second video file (continuing the video recording on the second file), the recording time is sharply reduced) This problem on Hellobox 8 firmware is mentioned on the forum from end of August 2019
2. TIMESHIFT does not work with encrypted channels.
This problem on Hellobox 8 firmware has been mentioned on the forum since July 2020
3. Associated with Hellobox 8 NEW version (in standby mode the processor remains under full load)
I myself mentioned this problem on Hellobox 8 NEW firmware on the forum on November 4, 2020, starting with firmware 202001027A
I subscribe, you are absolutely right!
With new firmware nothing of what we were interested in has been solved ... not even one thing ... I'm sorry but I think there is no more hope.
It means that they no longer have an interest in selling or developing this box... this is certainly not the right way to increase sales.
arunkj
Post by arunkj » Wed Apr 21, 2021 5:03 pm
Sir nss 12 one tp 10985 H 45000 not opened in dvb player it always working on hd out please fix it
robicxb
Post by robicxb » Thu Apr 22, 2021 1:04 pm
Cccam not connecting after update this firmware.. plz solve this issue
Adil
Post by Adil » Sat Apr 24, 2021 2:13 am
Tq my boss
Post by fenddick » Sun Apr 25, 2021 3:08 am
view:http://www.freedvb.com/viewtopic.php?f=25&t=18962
pitawin
Post by pitawin » Sun Apr 25, 2021 4:33 pm
Hellobox8 preset channel backup not working please fix it.
pitawin
Post by pitawin » Mon Apr 26, 2021 1:32 pm
H8 latest firmware version is hanging when connected to iptv. So frustrating, please fix this issue, can't use iptv due to freezing i don't know if it is only my stb. I have done factory reset several times but experiencing the same problem within the channels.
xmh0511
Post by xmh0511 » Wed Apr 28, 2021 3:14 am
彩票游戏 wrote:
Thu Apr 15, 2021 1:32 pm
-4b45ff830ba28fe7.jpg请告诉我PLS码在固件里哪个文件夹,谢谢!
I admire your patience since I have seen many threads for this issue which you are keeping post. I would say it's almost no possibility to make the engineer adopt your good suggestion. I give up waiting for this function. I have bought another product that is good for customizing inputting `plsn` for the channel of ST-2. That's very wonderful, I never necessary to take the patience to wait for the non-possible things anymore. Moreover, the significance is that that box takes less cost than hello box 8 however supply more functions.
